Michael Jsmith
Grip
- Mar 14, 2001
Does the RCA DTC100 pass 480i through component outputs (I know you need the VGA/component adapter), or does it only pass 1080i?
I just bought a Sony HD100, and it will pass both 1080i and 480i through the component connection, so you don't have to change inputs. I'm thinking of taking it back, and getting the RCA, though, because the RCA's are so cheap right now, and with DVI/HDCP, I want to spend as little on an HDTV decoder that may be obsolete in a couple of years anyway--BUT, I still want HDTV now. Any thoughts or suggestions about what I'm considering? Would you keep the Sony? Take it back and get a good deal on the RCA?
Thanks a bunch.
mike
Consuming air and other valuable resources since 1953.
Thanks a bunch.
mike
