RCA Composite to S VHS?
Discussion in 'Beginners, General Questions' started by ChrisFR, Mar 5, 2004.
  1. ChrisFR
    ChrisFR Extra
    Feb 16, 2004
    18
    I need to attach my VHS player to my AV Receiver.
    All of my other devices (DVD/CABLE Etc.) are connected using S VHS.
    I would like to use S VHS with my VCR but it doesn't have SVHS out or in. Is it ok to use an adaptor or an RCA to SVHS cable? I know the signal will not be S VHS quality but will the AV Receiver now see the VCR as an S VHS device?
    Thanks for any advice.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,264
    72
    9,110
    Corpus Christi, TX
    Wayne
    Chris, welcome to the Forum!
    Actually, “S-VHS” is a VCR – aka “Super-VHS.” The connection you’re talking about is S-video. Don’t feel bad; it’s easy to confuse the two. Especially since S-VHS VCRs are the only ones that come with S-video connections! [​IMG]
    You can’t use an adapter, you need a converter. Radio Shack sells a cheap one for abut $20. As you already know, it won’t give you S-VHS picture quality from the VCR, but it will make the signal compatible with the rest of your set up.
    Wayne A. Pflughaupt
  3. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    PartsExpress.com sells one for $5. Get a shopping list together to help justify the shipping and save a few $...
