Rattling window
Discussion in 'Home Theater Projects' started by Jason GT, Sep 4, 2003.
  1. Jason GT
    Jason GT Second Unit
    Dec 12, 2002
    452
    I'm not a homeowner and I didn't stay at a Holiday Inn express last night [​IMG] so here's my problem, which I'm hoping you gurus can help me with.
    In an old house, I've got a single glass pane window in what I think is a thin aluminum frame. It's an absolute pain the bunghole when I'm trying to listen to music at even a moderate level, and definitely detracts from moviewatching.
    So, what can I do to fix this?
    thanks in advance.
  2. Telalun
    Telalun Extra
    Aug 6, 2003
    19
    On old aluminium windows with single panes you should have a plastic molding on the outside of the window that holds the glass pane in place. Pull the old molding off, pull the glass pane out, lay down a liberal amount of clear silicone caulk, put the glass pane back in, and put in new molding. Total cost $7 or less.
    I had the same problem once before.
    :b
  3. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    I live in a new house with expensive double pane windows - but the springs on the garage door make noise (seriously).
