Ram Diagnostic
Discussion in 'Computers' started by Andrew_A_Paul, Apr 30, 2004.
  1. My computer will shutdown and reboot on its own and i get a "system has recovered from critical error" message. Long story short i was told it could be the ram and i should get a diagnostics program (just search around on google) but havent been able to find anything. Are there any free ones out there? Or if i really want to find out if its the ram or not, ill have to take it somewhere to test it? Thanks.
  2. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    Memtest86 is still as far as I know the defacto standard for finding errors in memory. The program typically installs onto a floppy disk and then you boot your computer of the disk so that the memory program can run without the interference of windows.
  4. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    If you do need to replace your RAM, I hear that Kingston ValueRAM is both reliable and inexpensive. I have two sticks in my current desktop PC which has never crashed. YMMV
  5. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    713
    SF Bay Area
    Christian Behrens
    Yes, another vote for memtest86. Boot with it from floppy or CD and let it run for a while. If/When it spits out messages, it's a bad sign.
    -Christian
  6. Harold Wazzu
    Harold Wazzu Supporting Actor
    Oct 1, 2003
    885
    I used the Microsoft program to detect some errors with my stick of Crucial ram. It does work.
  7. Rob Gardiner
    Feb 15, 2002
    2,950
    Andrew,
    Another possible culprit is your POWER SUPPLY. Are you using the cheap-o PS that came with the case? A study at Tom's Hardware demonstrated that many power supplies fail at WELL BELOW their rated output! Unscrupulous manufacturers exploit the fact that there is no user-friendly "benchmark" for power supply output. Many folks who curse Bill Gates' name when their Windows box crashes on them should look at their PS instead.
    Fortron is a reliable brand. Their PSs keep running even at 80-90 watts ABOVE their rated output. (not that you should test this theory at home, kids!) [​IMG]
    Culprit #3 would be the chipset on your motherboard. You don't have a VIA chipset, do you? Their drivers are notoriously unstable. Updating to the most current drivers may help. Switching to a motherboard with the Nvidia "Nforce" chipset may give you better results. I've heard that the most rock-solid setup is an Intel CPU, Intel MB, and Intel chipset.
  8. It not the power supply that came with the case. This could be coming back f4rom a fried MOBO from over the summer. I got a new Gigabyte board and everything else seemed to be fine, so i didnt change anything. All the ATX red wires melted to the old MOBO So obviously i got a new one. This one should have more than enough power considering im not really running all that much 'under the hood'.
  9. Time to revive this thread. I ran the ram diagnostic recommended in this thread, and nothing panned out. I've read some more forums and talk to a few other people. One other think I found out and tried was a suggestion that it could be a problem with the system restore and a corrupt file and that to solve that is to go into the settings and turn it off, reboot, turn it back on, and reboot again. Well I did this and I didn't have the problem with my computer shutting down on its own for about a day. Now its back to shutting down on its own about 4 or 5 times a day. I've heard that even though the ram diagnostic didn't pan out it can still be the ram. Another suggestion was a virus (only a small possibility, I run an issue of McAfee from the university that they run updates for students so they can keep out viruses they know are common on campus. I'm going to try and get a hold of a DDR chip and run it for a week or so and see if the problem is solved. Does anyone have any other ideas or suggestions? Thanks.
  10. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    Overheating maybe??
  11. pretty much got a no on that. besides i took the side cover off and it runs cool enough. very very very little heat coming out of my case/cpu
  12. I should add that I've had this hardware setup long enough and obviously has not always done it. I cant see what i've installed lately that would cause it (software issue). The only other thing: since i did fry my board last summer and replaced it, maybe it just took this long for the ram to give out and this is the problem. Like i said ill try and dig up a slot of DDR 256mb or soemthing and see what happens.
    BTW The log it creates after the restart when it shuts down is a minidump file (.dmp). Would this not also point to the ram being corrupt. The way i understand it is that the computer craps out when trying to write something to memory and creates this minidump log. Anyone know something further on this?
  13. Magnus_M
    Magnus_M Stunt Coordinator
    Jan 9, 2002
    82
    The possible culprits as I see them:
    1. Defective powersupply - Not so likely since you replaced the old one.
    2. Defective memory - Memtest is quite good at finding errors, as you passed the test I would say no to this one to.
    3. Defective motherboard - Same as the powersupply (ie replaced recently)
    4. Damaged installation of operating system - Always a possibility, an installation of Windows might last the computers lifetime but might just as well give up after a few weeks. YMMV
    5. Damaged CPU - As I don't know what happened to your computer during the summer (when yor motherboard and powersupply got fried) this could be the problem.
    My experience is that if a motherboard/PSU gets fried it's not uncommon that it takes other parts with it, also keep in mind that while a CPU might seem alright at the time it could very well be damaged.
    A damaged CPU could work pretty much as normal but crap out if pushed a little.
    6. Some of the replaced parts might have had a manufacturing error, but in these cases the often come dead on arrival.
    My recommendation would be to re-install your operating system, if the problem persists then (if possible) try another CPU to see if thats the problem.
    Just my 2 cents [​IMG]
