radio shack spl and adjustments
Discussion in 'Home Theater Projects' started by KevinW, Feb 12, 2005.
  1. KevinW
    KevinW Stunt Coordinator
    Dec 11, 2000
    187
    I've downloaded the meter correction sheet from Rives Audio's website and just need someone to verify my thinking on using the corrections.
    Using homemade test tones, I will add the correction amounts to the measurments I get. Correct?
  2. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    Yes. For instance, if you measure 80db at 20Hz, you would add 7.5 to it, for a true reading of 87.5, and so on and so forth...
