Radio Shack Correction Values - More
Discussion in 'Archived Threads 2001-2004' started by Jon M, Jan 7, 2002.
  1. Jon M
    Jon M Agent
    Apr 30, 2000
    27
    I have a question about the correction values. How do you determine correction values for frequencies between the ones listed. Is a best guess close enough? Also, with a program like ETF, does the mic correction file correct the response only at the specified frequencies, or does it compensate over the entire range?
  2. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Were you able to construct a microphone calibration file for ETF from the format I gave you?
    I'm not sure I would worry about values in-between, just let ETF use the corrected values as given. The RS SPL meter is not a calibrated mic and not all RS meters will necessarily match this correction file. If you want more accuracy you will need to buy or build a calibrated mic/pre-amp setup.
    For more info on building go here:
    mic & preamp
    BruceD
  3. Jon M
    Jon M Agent
    Apr 30, 2000
    27
    No, I have not been able to get it to work yet. I created a file which looks exactly like this:
    Radio Shack Low Frequency Correction File for ETF
    10.00020.0000.000
    12.50016.5000.000
    16.00011.5000.000
    20.0007.5000.000
    25.0005.0000.000
    31.5003.0000.000
    40.0002.5000.000
    50.0001.5000.000
    63.0001.5000.000
    80.0001.5000.000
    100.0002.0000.000
    125.0000.5000.000
    160.000-0.5000.000
    200.000-0.5000.000
    250.0000.5000.000
    315.000-0.5000.000
    400.0000.0000.000
    The measurements did not look any different with and without the file. Any ideas? I am going to write up a step by step process to use the Feedback Destroyer and ETF after I get this final step. I did get the sub to measure very well though, factoring in the correction values by eye.
  4. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Did you buy ETF5 or are you using the free download?
    BruceD
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I just interpolate at the pts I need in between the known measurements. If you graph it, it is a pretty well behaved curve.
  6. Jon M
    Jon M Agent
    Apr 30, 2000
    27
    I am using the demo version. Does this make a difference? I didn't think that the demo eliminated the mic compensation does it?
  7. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Jon,
    I don't know about the latest revisions, as I tried and bought the software when it was at ETF4 back in 1999 or 2000. At that time the free download didn't allow mic compensation files to be loaded.
    BruceD
