Chu Gai
- Jun 29, 2001
Recently, the question of whether their component and AV cables were the same or not came up. I've finally received the info from RS which I give below. It appears the main difference is that the A/V cable is an effective 22 gauge while the components are 20 gauge. The price differential was approximately double for the components. Enjoy
6' component (15-1563)6' A/V (15-1508)
Conductor -- 7 x 0.005 Copper (20 AWG) 7 x 30 (22 AWG)
Insulation Diameter -- 0.136 0.136
Insulation Wall Thickness -- 0.053 0.053
Insulation Color -- Yellow / Red / White Yellow / Red / White
Insulation Compound -- Foam Poly Foam Polyethylene
Braid -- 4 x 0.005 Copper (4 x not given)
Braid Coverage -- 58.80% 58.8%
Jacket Diameter -- 0.725 x 0.235 0.748 x 0.236
Jacket Wall Thickness -- 0.039 0.04
Jacket Web Thickness -- 0.010 (not given)
Jacket Color -- Black Black
Connector -- Gold-plated encapsulated RCA plug with spring (not given)
Connection -- Crimped (not given)
