Radio Shack Antenna Bow Tie Antenna
Discussion in 'Archived Threads 2001-2004' started by Kenny C, Dec 7, 2002.
  1. Kenny C
    Kenny C Agent
    Nov 16, 2001
    44
    Does anyone have Radio Shack Bow Tie Antenna Part number is 15-623 ? How did you hook it into your TV. Has those 2 plugs and my Zenith SAT 520 takes a coax connection ?
    What do i need to do ? Is there any booster also to increase the range ?
    Thank you
    Kenny
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,761
    485
    9,110
    You need a 300 ohm to 75 ohm transformer, try Radio Shack catalog number 15-1230, or 15-1140 (or something similar if you're at the store). You may have to solder the 2 U-shaped connectors together.
    The double bow-tie antenna is discontinued, but people have had some luck finding it at local stores, or on Ebay.
    Re: boosting an antenna's range, you'd have to look at amplified antennas (I don't know much about them), but I don't know how much more range you get from them either.
  3. Kenny C
    Kenny C Agent
    Nov 16, 2001
    44
    Thanks Patrick for the reply back. I will make a stop over RS to pick up the transformer.
