Rack Questions
Discussion in 'Home Theater Projects' started by Lance Nichols, Dec 23, 2003.
  1. Lance Nichols
    Lance Nichols Supporting Actor
    Dec 29, 1998
    726
    Ok, I managed to grab two old DEC racks from the office. One is being/will be used for my NOC. It will be in separate location, so no worries about cabling, etc. getting mixed up. The other will have a niche built for it in the HT, allowing me roll it our for replacements/etc.
    Questions I have, has anyone used old computer racks successfully? I know that they are essentially the same, a 19" rack is a 19" rack, after all. Guess I am just looking for some suggestions, or possible issues.
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    As long as it can hold your equipment and you're happy with the appearance, go for it.
  3. HankM
    HankM Second Unit
    May 15, 1999
    332
    It should be fine as long as your gear isn't to heavy. A solid level rack is better than a flimsy rack with to much weight.
