Quiet down the fan??????????PLV60HT
Discussion in 'Archived Threads 2001-2004' started by Scott Holt, Feb 18, 2002.
  1. Scott Holt
    Scott Holt Agent
    Jan 23, 2002
    28
    Can a person quiet down the fan of the 6oht without making a hush box????? I have heard that some replace the fan and if so how and with what?????????
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Some folks have taken a length of clothes dryer vent hose, connected one end to the projector and put a fan at the other end led through a hole in a wall into a different room. The fan in the projector is disconnected.
    Don't use garden hose or even vacuum cleaner hose, you won't get enough air flow to cool the projector.
    Video hints:
  3. kirk sutter
    kirk sutter Auditioning
    Feb 17, 2002
    Is it really that loud? I was thinking of purchasing one, but now you have me concerned.
  4. Scott Holt
    Scott Holt Agent
    Jan 23, 2002
    28
    No not really but my wife thinks it should be perfectly quiet. She lets me have almost everything I want so I thought I would try and please her.
  5. Ray Melnik
    Ray Melnik Agent
    Feb 18, 2002
    33
    Listen to see if you hear the fan change speeds. I have a Sanyo PLV-60 and it is very quiet. There might be something wrong with the unit. I mounted mine on a ceiling shelf and from there it is very low compared to even the lowest movie sound.
  6. Jim Ferguson
    Jim Ferguson Stunt Coordinator
    Sep 9, 1998
    83
    I have the SE13HD which is the same machine, only with a Boxlight label. I find it to be much louder than I would like. It's not as loud as the NEC LT150 that I used to have, but it's way louder than my 150 pound Barco CRT projector...
