Ryan Peter
- Sep 15, 1999
can i install windows 2000 on top of windows xp without having it eat up windows xp?
thanks
thanks
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)WINNT="Windows XP Professional" /fastdetect
C:="Windows 98 Second Edition"
If it does, save and close it. The next step is to delete the NT OS setup files from your hard drive. If I remember correctly, NT and 2k put these files in their own directory on the C: drive. XP probably does the same, but they might be in the WINDOWS directory. You'll know them when you see them - they have very awkward names and are usually the first directories listed.
That should leave you with a restored boot loader. Kind of convoluted, huh?
