Quick Sub Question
Discussion in 'Speakers & Subwoofers' started by Allan.G, Feb 27, 2004.
  1. Allan.G
    Allan.G Auditioning
    Jul 10, 2003
    14
    Never owning a sub before I need some help!
    I was looking at a pic of the back of the SVS pc-plus subs.
    I noticed that it looked like you could hook up regular speaker wire or a sub cable (RCA).
    Am I correct, If so which is the better way to go? and do you need two of them? I did not know a sub had a left and right connection LOL
    I'm prewiring now and need to know what to put in the walls
    Thanks in advance for putting up with a noobie![​IMG]
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    I wouldn't worry about the speaker wire inputs/outputs on the sub. Those are rarely, if ever, used in an HT setup these days. Just wire for the LFE cable that will run from the receiver to the sub.
  3. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    One single RCA terminated cable is all you need. The AVR's sub-out to either L or R in on the SVS will be fine. The speaker wire route would be if you didn't have a sub out and/or no crossover on your AVR, though the crossover will still work with the RCA input. Using a Y-cable to have input on both the L and R may give a stronger sub signal to help with the auto-on feature if your receiver had a weak output, but having had two SVS's I never found it necessary.
  4. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    The speaker cable connection is a carry-over from the "stereo only" days where you used the sub's amp crossover to manage the signal between the sub and the L&R mains.
    With today's bass management done at the preamp or receiver level it is no longer needed.
  5. Allan.G
    Allan.G Auditioning
    Jul 10, 2003
    14
    Wow thanks for the quick replys guys!
    That's what I needed to know. I purchased one sub cable from bluejean cables, and already have it ran. then I started looking at the back of the sub and got confused.
    So I should be set
    Thanks for helping me out.
