Quick Speaker hook up question
Discussion in 'AV Receivers' started by Christopher_R, Sep 16, 2003.
  1. Christopher_R
    Christopher_R Auditioning
    Dec 14, 2002
    12
    I have a pair of paradigm monitor 7s that are equal distance from the tv. My question is since my cabinet that holds all my av equipment is on the left side. I will need about 7 ft to connect my monitor 7 on the left but I will need a much longer length the speaker on the right. Will it make a difference in sound if the cables are not cut to the same length? Thanks
  2. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    Not at all in this living/family room environment (that is, no studio-length runs).
    Just cut the speaker wire according to how it lays along the baseboard and out to the spkr, leaving 12-18inches for position play.
    This might be the time to further refine speaker position for best imaging etc before making final cuts. But wire is cheap...
