Robin Smith
- Sep 27, 2000
Hi,
I am still on my quest for a router (mostly slowed by the money situation). I have done my research and followed the advice form my previous thread on the subject. I am down to two models and am wondering the best route to take (pun intended).
I am considering the Bosch 1617EVS and the Porter Cable 690.
Basically, if I get the Bosch, I get a fixed base, variable speed 2 HP - 12 Amp router.
http://www.boschtools.com/Tools+and+...tem_no=1617EVS
For the same money, I can get the Porter Cable 690 fixed/plunge kit which is a 1.5 HP fixed speed router with interchangable bases and a handy carry case. You can put on the lighter ifxed base if thats what you need, or the heavier but more versatile plunge base.
http://www.porter-cable.com/cgi-bin/...&prod_id=693PK
Which would you buy? Both are vailable locally which is good for warranty reasons and ease of purchase.
I have seen the Bosch come in a kit with both bases but ym local store only has the fixed speed version (which is more than the porter cable one and I amgine the variable speed version costs even more
I am already spending more than I budgeted for as I was originally planning on getting a Sears $180 router but was talked out of it by the good advice here.
With the Bosch I could later add the plunge base for an additional $100 but that is a lot, I guess if I REALLY wanted it it I could justify the cost. I don't know how much more it is if the two bases come in the kit but I imagine it is more than I want to spend.
http://www.boschtools.com/Tools+and+...m_no=1617EVSPK
Basically the bottom line is, is variable speed worth giving up the plunge base for, or will I regret not having the plunge. If so, is the porter cable awesome enough that I shouldn't pony up the extra for the Bosch with the two bases.
I tried out the Bosch and it feels nice (it has wooden handles!) and it is lighter and more pwoerful than the Porter Cable.
Any advice would be appreciated.
Robin Smith
Robin Smith
