quick questions for Photoshop users
Discussion in 'Archived Threads 2001-2004' started by Jeremy Illingworth, Jan 24, 2002.
  1. Jeremy Illingworth
    Jeremy Illingworth Supporting Actor
    Nov 12, 2000
    535
    I have Photoshop LE and am considering upgrading to the full version but have questions that relate to me specific use of it.
    I do primarily black and white line drawings with it. Can a make a picture larger that a piece of paper and have it printed on several papers so I can tape them together?
    If I make a series of dots is there a tool to help me make a nice curve over them?
    jeremy
  2. Pamela
    Pamela Supporting Actor
    Mar 14, 2001
    779
    Yes, you can make a Photoshop image quite large and print it out in pieces. If you are doing line drawings, however, Adobe Illustrator would be a much better application for you. It is a vector based program, and is made exactly for the type of thing you are doing (black and white line drawings).
    I encourage you to try it out. Adobe has a free trial version you can download from their Web site. The tools for Illustrator work the same as the Photoshop tools, including the pen tool and bezier handles for curves.
    I use both applications quite heavily, with PhotoShop handling scanning and manipulation of photo images. I use Illustrator to create artwork.
    Hope this helps!
  3. Jeremy Illingworth
    Nov 12, 2000
    535
    I'd rather just get Photoshop if it'll do the trick. This isn't something I do a lot of so I'd rather not buy Illustrator if I don't need it. I'm still saving money to upgrade the old P133 here.
    jeremy
  4. Ken Wagner
    Ken Wagner Stunt Coordinator
    Feb 21, 1999
    84
    I have to agree with Pamela about Illustrator. It is much better suited to line drawings. You can do them in Photoshop but you won't have the smooth curves you can achieve in Illustrator. See if you can find an older version of Illustrator that a friend doesn't use anymore or search on Ebay. You may save some money and get a great art tool.
