Quick question on Paradigm Reference Speakers and Pioneer Elite VSX-39TX Receiver
Discussion in 'Archived Threads 2001-2004' started by Dan Brodin, Jan 16, 2002.
  1. Dan Brodin
    Dan Brodin Stunt Coordinator
    Mar 28, 2000
    142
    Can I hook up a Paradigm Reference setup which are rated at 8ohms to my Pioneer Elite VSX-39TX rated for 120x5 into 6ohms?
    Are there any problems in this potential combination of hardware?
    Also even if it will work with no problems are there any disadvantages to having 8ohms speakers setup on a 6ohm receiver?
    thanks
    -Dan
  2. Ray O
    Ray O Extra
    Dec 4, 1998
    16
    I have Paradigm reference model 60's hooked up to my 39TX.
    I have the speakers setup in a separate room from the receiver (speaker "B" setting), as the Paradigms are used strictly for music. Have no problems with this setup.
    Ray
  3. GregoriusM
    GregoriusM Second Unit
    Jul 31, 2000
    278
    That's merely a rating of watting into 6 ohms. It is not an indication that it won't handle an 8 ohm speaker.
    You will be fine, and the Pioneer's match up well with the excellent Reference line from Paradigm.
    ... Greg
  4. Evan H
    Evan H Stunt Coordinator
    Apr 10, 2000
    95
    correct me if I'm wrong, but wouldn't it be safer to connect 8 ohm speakers to a receiver rated at 6 ohms than vice versa because a receiver rated at less ohms would be designed to send out more current without clipping, and therefore give a cleaner signal to the speakers?
