Quick Question - MALE Facial Care
Discussion in 'After Hours Lounge (Off Topic)' started by NolanJ, Feb 12, 2006.
  1. NolanJ
    NolanJ Second Unit
    May 1, 2004
    451
    2
    OK, so in what order do you do these three things:
    shower, shave, apply moisturizer
    My girlfriend insists I start using moisturizer for my face, but I'm not sure when to use it. Help a brotha out!
  2. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    "I use a deep pore cleanser lotion. In the shower I use a water activated gel cleanser, then a honey almond body scrub, and on the face an exfoliating gel scrub. Then I apply an herb-mint facial mask which I leave on for 10 minutes while I prepare the rest of my routine. I always use an after shave lotion with little or no alcohol, because alcohol dries your face out and makes you look older. Then moisturizer, then an anti-aging eye balm followed by a final moisturizing protective lotion."
    -Patrick Bateman-
  3. DougR
    DougR Second Unit
    Jun 15, 1999
    354
    Shower, Shave and Rub my face with a Brillo Pad.
    Manly....YES !![​IMG]
  4. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    I do this.
    In the shower I wash my face with Nivea for Men extra gentle face wash (my skin is fragile [​IMG]). Twice a week I will exfoliate with Nivea for Men face scrub.
    I only shave a few times a week so on days I shave: I shave and then use NFM soothing lotion on areas I've shaved. On the rest of my face and on days I don't shave I use the NFM extra soothing moisturiser.
    That's my daily system. [​IMG]
    Check out this site
  5. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    I shave in the shower. It's a much better shaving experience. Just get a cheap fog-free mirror from Wal-Mart to see if shaving in the shower is for you. If it is, then you can get a better mirror that will last longer.
  6. Carl Miller
    Carl Miller Screenwriter
    Mar 17, 2002
    1,461
    Seth, can you recommend a better mirror? The ones I get only stay fog free for a few weeks. Found wipes that re-coat the mirror with anti fog, uh, stuff. But that lasts a few days.
    Back on topic...Moisturize after showering and shaving would seem to make sense to me. But I don't know why.
  7. Adam Lenhardt
    Adam Lenhardt Executive Producer
    Feb 16, 2001
    18,413
    2,835
    9,110
    Albany, NY
    What I do is, I shave by feel in the shower, then do touch-up work right when I get out (while my face is still moist)
  8. SethH
    Dec 17, 2003
    2,867
    Well, this is the one I plan to get after my wife and I move in a couple months. It's expensive, but it attaches to your water line and runs water into the mirror. This makes the temperature the same on the inside and outside of the mirror which keeps it from fogging up. This is supposed to be far superior to the chemicals used in cheaper mirrors.
    Here's the one I plan to get: http://www.sharperimage.com/us/en/ca...atid__43479900
    They also make a less expensive version that I've seen at the store, but I couldn't find it on their website. It uses the same method, but doesn't have the magnification or the light on it. I think it goes for about $60
  9. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    "OK, so in what order do you do these three things:
    My girlfriend insists I start using moisturizer for my face, but I'm not sure when to use it. Help a brotha out!"
    This is the correct order...
    shower, shave, apply moisturizer. The moisturizer is the last thing you apply. It is suppose to help your skin retain moisture; thus keeping it looking younger and healthier.
  10. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    In chronological order....shower.
    Mort (who finds shaving barbaric [​IMG] )
  11. Hunter P
    Hunter P Screenwriter
    Sep 5, 2002
    1,483
    Exactly what I was thinking. I always try to model my lifestyle after Patrick Bateman.[​IMG] :b
    Anyway, serious question for you, Nolan: Do you think you need to use moisturizer? Zillions of men since the dawn of time have gone without moisturizer and they seemed to make it through life just fine.
  12. Spencer M
    Spencer M Extra
    Jan 3, 2006
    23
    Bed Bath Beyond has a selection of shaving mirrors. They range in price from 8-30 bucks. I bought the 10" $20 one and it doesn't fog but does require a spray of soapscum remover every month or so.
  13. JonZ
    JonZ Lead Actor
    Dec 28, 1998
    7,798
    11
    I used to shave before the shower, none of that moisturizer or aftershave stuff for me. When I shaved after or during showers, no matter how careful I was,I found I cut very easily.
    I dont really shave anymore.
    Ive had a goatee forever but the past few years, have just been wearing a beard. I was only getting 1&1/2 use from each razor and theyre expensive.
    I use a electric and scissors to clean it up once a week and take it down when it gets a bit unruly.
    Ill actually shave it off and begin again maybe once every few months.
  14. Neal_C
    Neal_C Second Unit
    Mar 15, 2001
    476
    I shave with an electric razor, then shower and apply moisturizer.
    Laugh if you will, but my best friends wife started me using Mary Kay facial products and in just a couple months I have gotten lots of compliments on how much younger my skin looks. I use the TimeWise face wash in the shower and follow that with TimeWise moisturizer when I get out.
    I'm 28, but since I spend so much time in the sun, my fiancee said I looked in my early 30's when we met 7 months ago. Now after using the Mary Kay stuff for a couple months, she and other people say my skin looks like I'm 24 or 25 again.
  15. Randy Tennison
    Randy Tennison Screenwriter
    Jan 5, 1999
    1,099
    Randy
    I shave in the shower, and use Clinque for Men. I love the face scrub once a week. That's when I change blades, and man, that gives a smooth shave.
    Then, some face soap, and afterward, post shave healer and some M-lotion on my dry spots.
    I wish my complexion showed some sign of the trouble I go through.
  16. Russell G
    Russell G Fake Shemp
    Sep 20, 2002
    11,486
    701
    9,110
    Deadmonton
    Russell
    I have very sensitive skin, and exema to boot. Here's what I use, to stay mostly blemish free:
    Don't shave in the winter, the wild Rasputin beard look is hot with the ladies. Otherwise, shave.
    I then use Body Shop Tea Tree oil daly facial soap, and twice a week I use the exfoilitaing scub. This well get the shaving cream off, as well as any other dirt on your face.
    Next, I use the freshiner in the same line, you just wipe it all over your face with a cotton ball/pad. This gets rid of remaining soap traces and oily spots.
    Than the gel moisterizer, as the freshiner can dry out your face.
    I tried the nivia for men, but the scent in it (I pressume it's ythe scent) made me break out. The Tea tree oil line at the body shop has no added perfume, and is pretty much the only product I have used that doesn't make me break out.
  17. Julian Reville
    Julian Reville Screenwriter
    Aug 29, 1999
    1,195
    1- Use combat knife to break ice in ammo can.
    2- Lather up using shaving brush & Lye soap.
    3- Scrape face using straight razor that hasn't been sharpened since the Normandy invasion.
    4-Apply protective layer of camo makeup.
  18. James T
    James T Screenwriter
    Aug 8, 1999
    1,643
    You don't happen to work for Nivea, do you? [​IMG]
    I use Nivea face scrub as well and use it daily, then again, I shave daily (or should, but some days, I'm just too damn lazy).
    I also like to shave in the shower. The sliding doors have a mirror on them, so I don't need any store bought mirrors to assist me.
    I tried shaving after my shower a couple times and didn't like it. It wasn't a smooth shave and I think I cut myself pretty bad too [​IMG]
  19. Richard Travale
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    Hah, I wish. It would save me a few bucks.
    Nah, I just stumbled across their product and liked it a lot.
  20. Luis Esp
    Luis Esp Supporting Actor
    May 25, 2001
    583
    Remember sunscreen is your friend. No matter what skin colour you are, everyone should be sun smart.
