Quick question from Noobie
Discussion in 'Speakers & Subwoofers' started by Allan.G, Feb 23, 2004.
  1. Allan.G
    Allan.G Auditioning
    Jul 10, 2003
    14
    I am prewiring now and I ordered some of this for inwall speaker wire. Ultralink Cable -In-Wall 4 Conducter 14awg. Now I am planing on buying a SVS sub do I need to buy a different cable or can this cable be used.
    Sorry if this is a stupid question but need to know LOL
    Thanks in advance
  2. Mike_Skeway
    Mike_Skeway Second Unit
    Jan 13, 2004
    265
    If it is a powered sub you will need a sub cable (coax), if it will be passive then regular speaker wire will work. Which sub are you looking to get?
  3. Allan.G
    Allan.G Auditioning
    Jul 10, 2003
    14
    Thanks for clearing that up for me, it was like a light came on Duhh. Was looking for a powered sub so I guess I will run coax and that wire so I will have both options.
    I don't know which sub I'll get, I thought when I got closer to getting one I would call them and see which one they suggest. Room size is 12'X 18'X 8', any suggestions?
  4. Mike_Skeway
    Jan 13, 2004
    265
    [​IMG]
    Best bet is to contact them with you room and listening habits. They will point you in the right direction as for what will fit the best.
  5. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    Twin PB4+'s should fit the room nicely.[​IMG]
