Quick question for Mitsubishi RPTV owners
Discussion in 'Displays' started by Skip Hammerman, Feb 16, 2004.
  1. Skip Hammerman
    Nov 30, 2001
    28
    My 73713 should be arriving this week. (Can't wait, I have my new Hughes HTL-HD and Denon 2900 already hooked up to my old system). I do need to get my cables and in order to determine the required length I need to know what side are the Mitsubishi rear inputs on? (Left or Right when facing the unit from the front as if viewing it.)
    Thanks -
  2. Robert Houghton
    Oct 30, 1998
    44
    I have the Mitsubishi 65513, and the connections are on the right, when I stand in front of the TV. I do believe your set would be the same. I know that because of this, I have had to use 12' cables instead of 6'. You can always double check at Mitsubishi's site. It's at www.mitsubishi-tv.com.
  3. Skip Hammerman
    Nov 30, 2001
    28
    Robert -
    Thank you -
    (The Mitsubishi site does not show the location, only a detail picture of the in and outputs. Same with the users manual)
    Skip
  4. GeraldK
    GeraldK Agent
    Mar 16, 2003
    27
    Skip, our '04 65413 also has them on the bottom right when facing the front of the TV. I had to use longer cables as well.
  5. Joseph Jison
    Joseph Jison Auditioning
    Dec 21, 1999
    I have the 73713 - and the a/v panel is on the bottom right. My cable length varies from 3m to 4meters.
