Quick question for Excel experts
Discussion in 'After Hours Lounge (Off Topic)' started by Brian Perry, Apr 28, 2004.
  1. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
    I have a speadsheet that includes multiple rows with redundant data that I need to consolidate into summary lines. For example, let's say I have the following ten rows (in three columns):
    20 March Soybeans
    25 March Soybeans
    15 May Soybeans
    93 May Soybeans
    42 July Corn
    11 July Corn
    32 July Corn
    431 July Corn
    16 September Corn
    32 September Corn
    and I want those lines to consolidate into:
    45 March Soybeans
    108 May Soybeans
    516 July Corn
    48 September Corn
    or even:
    153 Soybeans
    564 Corn
    Can this be done without manually inserting a sum function between each different month and/or commodity? I'm used to creating AS/400 queries where stuff like this is a breeze but now I'm being given the data in spreadsheet format and I'm having a tough time producing the same results. Someone I know mentioned a "pivot table" function in Excel, but I tried it and it didn't quite give me the results I need (the data I'm working with has many more rows and columns than the example above so the pivot table was unwieldy--we're talking about thousands of rows).
    Thanks!
  2. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    Look at the DSUM function. The help in excel is quite good for all of the formulas, but that should get you started.
  3. Todd Henry
    Todd Henry Second Unit
    Feb 4, 2002
    324
    You can also use the subtotals function under the Data menu if you data is sorted by month so all of March is grouped together.
    Todd
  4. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Pivot Table.
    (edit)
    Sorry, didn't see you mention PTs before. As Alex says below they're probably the most straightforward way of doing what you want.
  5. Alex Spindler
    Alex Spindler Producer
    Jan 23, 2000
    3,971
    Yeah, I was going to say if you have specific sets of criteria you're after, the very fast way of doing it is applying an Autofilter so you have drop down criteria for every row. Then add the following function somewhere off to the right on Row 1:
    =SUBTOTAL(9,A:A)
    Assuming A is the column you want to sum, you just have to choose the right criteria for the drop downs for what you're after and record the information separately.
    If you have a series of criteria you're after repeatedly (like if this is a weekly report and they need tons of different result values), you may just want to build a set of SUMIF or DSUM calculations and build from there.
    I'm still not sure why the Pivot Table isn't good for you, as you can just select the columns that you want and they create just about any sum combination you could be after.
  6. Denward
    Denward Supporting Actor
    Feb 26, 2001
    552
    Set up your pivot table with MONTH in the columns and CROP in the rows and the QUANTITY in the body of the pivot table. You'll end up with a 12 column table with a row for each crop and totals for each row and column. That seems like the perfect way to summarize your info. Pivot tables are very good at summarizing thousands of rows of data.
  7. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    I just want to say that I love Excel. It is IMO the most versatile piece of software ever created.
    Word blows.
  8. Alex Spindler
    Jan 23, 2000
    3,971
    You want to know the most depressing thing ever? Try recreating even the most basic Excel formulas in Access. Both Microsoft, but one has the formula versatility of an amoeba by comparison.
  9. Dave Poehlman
    Mar 8, 2000
    3,813
    Oh I use Excel for everything... making signs for the office, football pools, using its visual basic macro capabilities I can make it talk with other applications..pulling data, manipulating it, puking it back... it's awesome.
    Word still blows.
