quick question before I buy
Discussion in 'Archived Threads 2001-2004' started by Josh.L, Oct 22, 2002.
  1. Josh.L
    Josh.L Agent
    Oct 5, 2002
    31
    I was looking at a chart that compares the HK225 to the 320 and one of the things the 320 has that the 225 doesn't is "Wideband, HDTV-Ready Component Video"
    Can anybody tell me what this is? Also, any votes for a refurb 320 vs. a new 225. I can't make my mind up.
    And how important is, "dual, Independent Power Supplies for Front and Rear Channels." The 320 has this and the 225 doesn't.
    Thanks for any help,
    josh
  2. Tim_J_M
    Tim_J_M Agent
    Oct 3, 2002
    30
    Get the 320, and if its refurb be sure its direct from Harman Kardon. The 320 is GREAT and youll be very happy with it. BTW the dual powersupplies helps when you start to run more power into your speakers. if you dont have efficient speakers, the dual power supplies will help as you try to push them.
