Vince Maskeeper
- Jan 18, 1999
I don't know much about this, but a friend asked me, so I figured I'd ask here:
The RJ-45 port on the Xbox is used for the Xbox live online gaming system. I am also under the impression that this port is used for directly linking two Xbox consoles. Is this correct?
If you do link 2 directly- what cable do you use? Does it need to be a crossover cable? I assume it works like and NIC card- unit to unit would use a crossover, and going to a hub would be a standard Cat5/RJ45 cable.
Am I right?
-Vince
Am I right?
-Vince
