Christopher Chung
- Jul 28, 2001
Okay, this question is probably a no-brainer but anyways...
I want to put a 250MB Zip drive in my computer, but I just want to buy the OEM part, instead of shelling $60-$80 more for a retail version. Now the question I have is will my OS (WinXP) be able to regonize the drive? Should I encounter any problems without having the drivers (software?) the otherwise come with the retail versions? If or if not, what else should I have on hand to fix the problems? (okay, that was more than one question, sorry!)
Again, thanks for any help!
Chris
Chris
