Quick Qestion regarding Better Cables Bi-wired Premium Speaker Wire
Discussion in 'Archived Threads 2001-2004' started by Dan Brodin, Mar 7, 2002.
  1. Dan Brodin
    Dan Brodin Stunt Coordinator
    Mar 28, 2000
    142
    I recently got my Paradigm Reference Studio 100s and decided to bi-wire them to my reciever (they will soon have their own 200x2 Parasound amp). I know in the manual Paradigm states the top set of binding posts are for the high frequency and the bottom set are for the mid/low freqency, but my question is are the better cables setup in the same fashion? Is one pair specifically for the highs and one for the mid/low? Or does it not matter which set you connect to the high and mid/low binding posts on the Paradigm Reference Series speakers? If there is an indicator on the the Better Cables speaker wire that indicates if a set is for high or mid/low I must have missed or be completely blind. [​IMG]
    Thanks for your help guys
    -Dan
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    Not sure about that particular manufacturer but usually the heavier gauge in these sets is for the Bass.
  3. Mike Butny
    Mike Butny Stunt Coordinator
    Mar 3, 2002
    66
    Check out Monstercables M series, they make very good bi-wire cables.
