Quick Help- XBOX Adapter
Discussion in 'Archived Threads 2001-2004' started by Brian Johnson, Nov 10, 2002.
  1. Brian Johnson
    Brian Johnson Supporting Actor
    Oct 21, 2001
    739
    I am getting an XBOX today and was looking at the adapters..
    The advanced AV pack seems to be the same as the HD-AV pack and the same price.
    So, even if I dont own a HD TV, would it be a safe assumption to just get the HD-AV pack?
  2. Brian Johnson
    Oct 21, 2001
    739
    Well, Let me add some details (the best I can [​IMG])
    TV: Has component & s-video in's
    DVD: Has component & s-video out, along with coaxial & optical audio out
    Reciever: accepts coaxial & optical audio.
    Right now I have S-video from DVD to TV, and coaxial audio from DVD to receiver.
    When I get the XBOX I was going to:
    Hook up my DVD component to TV, DVD optical to receiver optical, s-video from xbox to TV & xbox coaxial audio to receiver....??
    Any quick tips are helpful. Im getting ready to leave [​IMG])
  3. Evan Hartnett
    Evan Hartnett Stunt Coordinator
    Jan 9, 2002
    118
    If you can use a component connection (you have enough to plug in both the Xbox and the DVD player) I'd do it. If you have to pick with a component connection for the xbox or the DVD player I'd go with the DVD player, but that's just IMO.
  4. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
    There is no coaxial digital audio from the Xbox. Optical only.
  5. Travis Kolesar
    Travis Kolesar Second Unit
    May 16, 2002
    291
    If you get the xbox Monster Cables they are now offering a coax digital audio conector but I have yet to see one anywhere.
  6. Dave E H
    Dave E H Supporting Actor
    Apr 23, 2002
    829
  7. Brian Johnson
    Oct 21, 2001
    739
    Thanks Dave, thats what I did. I figured I saved money by NOT having to buy an additional set of component cables. I bought the HD Pack & one optical cable. So, I was only out 40 bucks. It looks fine, the audio is awesome.
