Quick Help Needed w/Sub Positioning
Discussion in 'Speakers & Subwoofers' started by Louisp, Mar 12, 2005.
  1. Louisp
    Louisp Stunt Coordinator
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    My Infinity sub is front firing with the port in the rear.
    The only wife approved location for my sub is behind the entertainment hardware which is a corner positioned at a 45 degree angle. To complicate matters one of the back walls is actually an arched opening into another room. Because of this opening the sub does not have a solid surface behind the port. Plus the woofer fires into the back of the hardware.
    My alternate plan is to mount 8" legs on the back of the sub so that it fires UP with the port opening pointing DOWN. The floor is carpet but if best I can place a hard surface under the sub and over the carpet.
    Please tell me if this is a workable alternative to normal placement.
  2. MikeNg
    MikeNg Second Unit
    Jan 22, 2004
    440
    I don't think anyone can tell you for sure - you'll just have to try it out to see. Small changes in position/rotation make a difference so it may work for you.
    You could also try just rotating the sub 90 degrees so that it fires toward one of the side walls. LF is by and large non-directional so you don't need to 'aim' it at the listening position.
    Mike
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Point the driver parallel to the longest wall for starters. I have a very similar setup. As Mike said, small changes can make noticable differences at your listening position. IMO, pointing it at the ceiling isn't going to buy you anything.
  4. Louisp
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    The reason for pointing it at the ceiling was so the intake was over a solid surface AND so the woofer was firing along an unobstructed wall. Aiming the woofer along the side wall has it firing into hardware and a fireplace.
    I appreciate your comments.
    Lou
  5. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    How much clearance do you have for the woofer? You really don't need that much. Also, not having the port firing into a solid surface is not a liability.
    If you don't have the option to move it to another location, then I guess it'll have to work. Maybe you'll get lucky.[​IMG]
    DJ
  6. Louisp
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    The woofer has about a 2' clearence. What do you think?
  7. David Judah
    Feb 11, 1999
    1,479
    It should be fine.
  8. Louisp
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    Does it matter if the sub is elevated 18" off the floor?
  9. David Judah
    Feb 11, 1999
    1,479
    I don't have any experience pulling the sub off the floor, but it always matters when you move the sub.
  10. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    The port is an inlet/outlet, but not the way most think it is. It's there to relieve pressure from the driver's movement, not to allow bass to flow out of it. 2 feet is more than enough; even just 6 inches should be plenty.
    Raising it 18" off the floor may help, but the exact height that works best/well will be determined by your room.
  11. Greg Bright
    Greg Bright Second Unit
    Feb 24, 2000
    265
    2
    110
    Gregory Bright
    I do believe that there is a point where most of the sound comes from the port and not the woofer itself. Otherwise the driver would self-destruct from over-excursion.
  12. MikeNg
    MikeNg Second Unit
    Jan 22, 2004
    440
    I believe that's the 'tuning point'.
  13. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    At the tuning point, most of the acoustic energy is coming from the port, but an equivalent reduction in excursion occurs, so the result is sort of a wash. Over-excursion will ultimately result in bottoming out, not quite instant self destruction, though it's not a good thing over time.
  14. Louisp
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    A hardy thanks for all the contribution's to this thread. After an evening of movie watching I can say that the sub has never sounded as good as it does now.
