(quick) dumb sub wiring question.
Discussion in 'Home Theater Projects' started by minhG, Jul 21, 2004.
  1. minhG
    minhG Stunt Coordinator
    May 6, 2004
    82
    i think i have this right, but i want to make sure.
    i have a dual vc (8ohm each) subwoofer. each vc is wired to a set of binding posts.
    if i use a small piece of speaker wire and jumper the + to + and - to - on the binding posts (from the outside of the box) will i get a 4ohm load to the amp if I plug the speaker wire from my amp to one set of binding posts?
    i hope that makes sense!
  2. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Correct, just so long as the jumper wire is large enough to handle the current of a single VC.
    GM
