questions regarding DIY subwoofer components
Discussion in 'Archived Threads 2001-2004' started by Dylan, Aug 28, 2002.
  1. Dylan
    Dylan Extra
    Feb 4, 1999
    23
    I've never built a speaker before so I have no prior knowledge on the specific details of building a sub. I am looking to upgrade my current 23W 6 inch Sony sub to one that will let you FEEL an explosion or a T-rex running by, not just hear it. However, my budget is rather limited. Thus, I wanted to know how much of a difference a sub whose max low freq. is 20 Hz would be from a sub whose max low freq. is 15 Hz. I was browsing through a Crutchfield catalog and I was looking at the car audio subs, boxes and amps and I'm wondering if I can just purchase a preassembled box like they use in cars for a sub and add a sub and amp? If I can, I was looking at the Pioneer TS-W384DVC 15" http://www.crutchfield.com/S-BFNtcB1...mp.asp?g=67800 or the Sony XS-L1536. They are both the same price ($160), but the Pioneer has a max freq. of 15Hz w/a natural resonance of 21Hz vs max freq of 18hz and a natural resonance of 23 Hz for the Sony. If there is little noticeable difference between 15 Hz and 20 or 25Hz, I would rather save some money and get a cheaper 20 or 25 Hz sub or just buy a premade home theater sub (I was recommended the AudioSource SW 15, a 15" 200W 25Hz max low freq. sub). All other things being equal, would a 500W 25Hz sub sound tighter than a 200W 25Hz sub and thus it is the max power that makes a difference in the very low freq? Another question would be the type of amp to get. Should I just looking for a mono channel that will handle the max wattage of the sub and allow you to adjust the freq cut off or is it more complicated than that? I've heard people say one should have an equalizer for the sub to get rid of any excess boomeness, is that possible through the amp? Are there different amps for car audio vs home theater? The room I'll put this in is a small (25 ft long by 15 ft wide) room with three walls (front, back, one side) if that information makes a difference.
  2. Rick Guynn
    Rick Guynn Second Unit
    Mar 23, 1999
    473
    You could buy one of those subs and stick it in a premade box, but neither one of those subs is likely to produce the SPL you would need in a room that size. The Xmax on the sony unit is only 4mm. You would do better to look at the DVC drivers from Parts Express or Adire Audio. Also, car sub boxes are usually small. Small boxes in a home environment usually require signficant ampage.
    Go to Adire's web site and read some of their white papers on Shiva applications. They should be very educational. You might even download LSPCad while you're there and play with some configs.
    As far as amp power... the power does not directly affect the sound quality. The power determines how loud you can drive the sub (assuming the driver you're using is suitable for the application).
    A decent DIY sub is going to cost $200-$300 + your time. If you have the desire and tools, it can be great. If you are exploring solely because of cost and aren't particularly interested in the educational aspect, you are probably better off just buying something.
    RG
