Questions on my new Samsung HDTV-ready monitor
Discussion in 'Archived Threads 2001-2004' started by Thik Nongyow, Jul 13, 2002.
  1. Thik Nongyow
    Thik Nongyow Stunt Coordinator
    Jun 3, 2002
    189
    On Thursday, I received by delivery my first HDTV-ready monitor from Samsung, model TXM2797HF. After a few days, I was able to customize it to a way according to my personal preferences. I am very satisfied with the TV after a few months researching it. However, there I have two questions on my TV that concerns me:
    1. How to remove the Velocity Scan Modulation effect from the TV screen?
    2. How to eliminate over-scan? It is a problem, as I lose about 10% of the screen, especially watching wide-screen movies.
    Any help is appreciated?
  2. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    TO get into the Srvice mode you should be able to ( I have the 3294HF) press mute-1-8-2- power. Go to VML and make sure it is set to no more then 10 (this will shut off or mostly elimahte VSM). As far as geometry, get AVIA or VE, use the overscan pattern and go into the gemoetry settings in the service menu (make sure you write down the factory defaults just in case) and play around with it until you get it right.
  3. Thik Nongyow
    Jun 3, 2002
    189
    That you for your help, but it seems that by pressing the numbers and the power button, I did not enter the Service mode. I am unsure whether to do this while turning of the TV or while it on.
  4. LaMarcus
    LaMarcus Screenwriter
    Mar 7, 2002
    1,619
    What does the VSM do? Why does every one shut it off? I would love to be able to fix the overscan on my wide screen I lose 5% according to VE.
  5. MikeyWeitz
    Feb 10, 2002
    939
    Do it when the TV is off. Make sure the remote is pointed directly at the TV.
  6. Thik Nongyow
    Jun 3, 2002
    189
    After many attempts to enter the Service mode, I was able to get into it. Now, what should I do now?
    I see this:
    Service / SIM-460A1
    Deflection
    480p Offset
    1080i Offset
    Video Adjust1
    Video Adjust2
    Video Adjust3
    Option (B0h 98h 03h)
    Reset (02-04-29)
    If I go to "Deflection," I get these options:
    V Amp
    V Shift
    H EW
    H Shift
    V Linearity
    Upper Linearity
    Lower Linearity
    VSC
    H Parabola
    Upper Corner
    Lower Corner
    H Trapezium
    Bow Angle V Position
    CXA Left Blk
    CXA Right Blk
    What should I do now, to deal with overscan and VSM?
  7. MikeyWeitz
    Feb 10, 2002
    939
    Looks nothing like my service menu. I would order the service manual. It will tell you what everything does.
