Questions for Onkyo tx sr600 SKS-HT500 owners
Discussion in 'Archived Threads 2001-2004' started by Jacqueline C, Mar 13, 2003.
  1. Jacqueline C
    Jacqueline C Agent
    Feb 10, 2003
    30
    Just ordered the reciever and speaker set. Wanted to get the cables and speaker wires before they arrive as I don't want to have to move the really heavy tv more than once to connect everything. I here I should replace the subwoofer cable and the speaker wire. So my questions are if I get 12 gauge speaker wire, do I need banana plugs or something or are the holes big enough to put the bare wire in? Should I settle for 14 gauge? Do I look for "subwoofer wire" per se or do I do a search for "coaxial cable" or what?
    BTW is anybody having trouble with Parts Express website? I was trying to look at cables there but my computer gets stuck each time I try to do a search. No other website does that.
  2. Adam Y
    Adam Y Auditioning
    Mar 10, 2003
    10
    I just bought that speaker set from the Onkyo website a week ago and hooked up this past Monday.
    I bought all of my cables from PartsExpress; the Dayton Audio line. As for the speaker wire, I bought a 50 ft. roll of 12 gauge Sound King. If your receiver has posts rather than spring clips than you should get some banana plugs from RadioShack. The speakers have spring clips so I just used bare wire on that end.
    PartsExpress didn't have the "subwoofer" cable so I just bought a regular yellow video cable that works just the same. Or you can use regular coax with F-to-RCA adapters from RadioShack.
    Adam
  3. Jacqueline C
    Jacqueline C Agent
    Feb 10, 2003
    30
    Thanks Adam. Did you use stands and/or brackets for the speakers? I thought I'd use stands for the fronts and surrounds and a bracket for the back speaker which I'm getting separately. Do you have any suggestions for stands and or brackets?
    thanks again
  4. Adam Y
    Adam Y Auditioning
    Mar 10, 2003
    10
    I bought a pair of Chicago Audio 28" stands from Circuit City for the fronts. They are pretty nice stands and easy to assemble for $60 but are a little light.
    I haven't decide what I'm gonna use for the surrounds since I don't have them hooked up yet. I live in an apartment so that's making me think twice about how I wanna go about mounting and wiring them.
    Adam
  5. RickBoiler
    RickBoiler Auditioning
    Mar 14, 2003
    6
    Did you buy the reconditioned Onkyo set-up (TXSR600 Package)?
    Any advise on buying reconditioned items?
  6. Adam Y
    Adam Y Auditioning
    Mar 10, 2003
    10
    I just bought the SKS-HT500 brand new. For only $245 you might as well buy new. It looks like they offer a pretty good extended warranty on refurbished products though.
    Adam
