Jeff_M
- Nov 26, 2000
I recently moved to a front projection setup (what fun!). One of the ancillary benefits that this provides me with is the ability to use 5 identical speakers. Obviously with a tube or RPTV, there is no way to put a standard speaker in the center. My question is whether using a horizontally oriented center channel is a compromise over using a speaker that matches the the others exactly(?). Has anyone here switched from a "voice matched" center to an identical speaker? What type of improvements did you hear?
