Boka
- Jul 29, 2002
I plan on purchasing a panasonic AE100 projector. This will be used exculsively for DVD viewing in a light controlled room.
Does anyone know of a good U.S. supplier or European supplier of this projector?
Does anyone have experience using the PT-AE100e (European) version of the projector or in using the American/Japanese version on 220v power?
Do most people run the projector in high or low (bulb/brightness) mode? Is there a quality difference?
What colour/gamma do I want for the screen. Pure white, slightly gray, etc...
Although I have complete control over the lighting, my room has alot of white surfaces (wall and ceiling). Would this affect the type of screen I should use?
I was planning on sitting about 9ft away from 6ft wide screen. Is this a good distance or will screendoor be extremely noticable?
Is there anything that can be done to improve the blackness of the blacks?
Many, many people say that the best picture is obtained when input is given through the VGA port. Is there any difference between using a HTPC and a DVD player with VGA video out?
