Questions about KVM switches
Discussion in 'Archived Threads 2001-2004' started by Matt Stryker, Apr 4, 2002.
  1. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
    I've been looking for a device to switch between my 3 VGA sources, and someone recently suggested a KVM switch. I've used them before at work, but never for HT applications.
    The one that I'm considering is this one:
    http://catalog.belkin.com/IWCatProdu...ries%2F ct_Id>
    Primarily for the higher video bandwidth vs. other KVMs, and the styling should look nice in the theater. Any reason why this will not fit the bill?
    Also, can KVMs pass component over VGA? My JVC DVD player is hooked up using a VGA-to-component cable, and it would suck for it not to pass through.
  2. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I use their olders ones at work and at home. The one you are looking at I think specs out better.
    I love those things - having multiple monitors and keyboards is a pain. Only time they aren't good is if you want to use one computer and someone else wants to do something as well on another one.
    Don't buy it from Beklin though. I usually get mine from www.buy.com at about 1/2 the Belkin price.
  3. Charles Bober
    Charles Bober Stunt Coordinator
    Sep 5, 1999
    199
    Hey Matt. That will fit the bill nicely. I use a Belkin at home and I've had no problems. If you need something smaller, I'd recommend something like this (I shall call him Mini-me....LOL): IOGear Mini-KVM
    As far as component to VGA, I see no reason why it won't work.
    Good luck.
  4. Matt Stryker
    Oct 12, 2000
    1,307
    It should get here Tuesday, I'll post a review when I get it all hooked up. Thanks for your help guys.
