Questions about digital connection (split from "Digital Output or Analogue Output for 5.1 playback?"
Discussion in 'Playback Devices' started by patrick korn, Oct 12, 2003.
  1. patrick korn
    patrick korn Auditioning
    Oct 11, 2003
    9
    for a couple of months i have been wondering about coaxial cable,s or Optical cable,s i mean witch one is better of the two it,s always the same questian some magezines says that optical is better and the others says that coaxial is better.is there a big diffrence?????thanks[​IMG]
  2. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    Digital is digital...
    The connection works or it doesn't. I have both (optical & coax).
    The coax connector is cheaper (usually).
    Soundwise, I am sure some of high-end folks would beg to differ, but I can't tell the difference.
  3. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  4. patrick korn
    Oct 11, 2003
    9
    oke thank guys but this is the big problem i have.i own a onkyo 701 thx reciever and a PIONEER laserdisc model 909dv the latest one with dvd.if i put the movie the ROCK wich is a dolby digital AC3 movie.my reciever gifs a PRO LOGIC sound.i have conect it with optical cable and coaxial cable and non gifs me the dolby digital sound???it,s a bummer becaus i own a lot of laserdisc,s with DOLBY DIGTAL SOUND TRACKS thanks
  5. Michael Reuben
    Feb 12, 1998
    21,763
    2
    You can't play DD tracks from laserdisc without first passing the signal through a demodulator. Check out the laserdisc section of the HTF Primer and FAQ (link in my signature below).
    BTW, I've split your questions into a separate thread.
    M.
  6. patrick korn
    Oct 11, 2003
    9
    thank a lot michael i will check it out [​IMG]
