Ted Lee
- May 8, 2001
hi all -
i usually use cd-creator, but thought (based upon recommendations from you all) to give nero a try. it seems pretty powerful, but it does one thing that totally annoys me.
what's with it "analyzing" my audio files before i can add them to the left-pane? it takes like 40 seconds (which is an eternity in pc time) to add each file. will it do this with data files too?
is there a way to disable it...i checked the preferences but couldn't find anything.
that alone will keep me from using this program.
thx!
thx!
