Question to iPod owners out there...
Discussion in 'Computers' started by Winston D, Jun 2, 2003.
  1. Winston D
    Winston D Agent
    Jan 21, 2001
    33
    I am contemplating getting one. Are the new ones compatible to both Mac and PC? Or you have to choose the PC version or the Mac version?
    Also, does it come with a software to convert my CD's to MP3's to transfer it to the iPod? I am new to this portable MP3 thing and would very much like to have thousands of songs to carry around with me.
    Thanks in advance.
  2. Patrick_S
    Patrick_S Producer
    Apr 1, 2000
    3,279
    102
    4,110
    The new ones work on both the PC and the Mac so you no longer need to specify which platform you are using.
    It does come with Musicmatch for ripping your CD using Windows.
    Down the road a Windows version of Itunes will be available so Windows Users will be able to rip in the new AAC format.
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    The mac/pc issue is really less complex than everyone seems to make it.
    It's just a question of how the Hard Drive is formatted out of the box, and what software is bundled with it-- but in both cases, you can reformat the drive and download the software- so a MAC version can become PC and vice versa.
    And, there are even applications out there that would allow you to leave it MAC format and still have your PC talk to it.
    As far as software- I'm not a big fan of musicmatch (the PC app)-- so I used CDEX to rip the songs (which is highly recommended) and then something caled Ephipod to put songs on the pod. Not quite as "do it all automatically" as Musicmatch- but I'd rather have my own control.
    -Vince
  4. Danny R
    Danny R Supporting Actor
    May 23, 2000
    871
    Is it possible to upgrade the hard drive easily? I've got some spare 40gig notebook size drives which I believe are the same size as whats in the Ipod. Just wondering if they made the case openable or not.
  5. Joel Mack
    Joel Mack Cinematographer
    Jun 29, 1999
    2,317
  6. Vince Maskeeper
    Jan 18, 1999
    6,499
  7. Joel Mack
    Jun 29, 1999
    2,317
    I stand corrected. Looks to be a PITA, though.
  8. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    As previously mentioned, the new versions support both PCs and Macs, but everyone forgets to mention that they don't support them both at the same time. If you connect an iPod to a Mac, it'll be formatted to use the MacOS filesystem. If you connect it to a Windows PC, it'll format it for use there. So don't look to an iPod as a good cross platform file transfer mechanism.
  9. Camp
    Camp Cinematographer
    Dec 3, 1999
    2,301
    Don,
    Read Vince's post. You can use a MacOS formatted iPod on a PC. There's a piece of software called MacOpener which allows Windows read MacOS drives. I haven't used it but it supposedly works really well for people who use both Macs and PCs.
  10. Thomas Newton
    Thomas Newton Screenwriter
    Jun 16, 1999
    1,567
    44
    1,610
  11. Danny R
    May 23, 2000
    871
    Yup, I noticed that while reading the links Vince posted.
