Question: Sony 32" TV Models
Discussion in 'Archived Threads 2001-2004' started by Mijang, Jul 30, 2002.
  1. Mijang
    Mijang Agent
    Oct 6, 2001
    27
    I want a Sony 32" TV that will support a progressive scan DVD player (I plan on purchasing the Sony DVP-NS755V). I don't want to spend more than $1500; I would rather spend around $1000. What are my options in terms of the various models available? Thanks in advance!
    EDIT: I've been doing a little research online and the KV-32HS500 and KV-HV600 both seem to meet my needs. What is the reason for the $200 price difference between these two models, as the specs seem the same to me?
  2. DanielSmi
    DanielSmi Second Unit
    Mar 20, 2002
    455
  3. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I guess the KV-HV600 is the XBR replacement. A few small inprovements to the HS500, and I guess a better warranty.
  4. Bob S
    Bob S Extra
    Dec 9, 1999
    21
    The most notable difference I believe (other than the warranty) is that the HV allows you to adjust the DRC level (even basically turning it off) while the DRC is always on 100% on the HS.
    Adjusting DRC is handy because DRC can make a mess of poor quality signals (like some cable systems) so turning it down improves the picture in those cases.
    I don't own either but this is what I have gathered from other posts I've read and from playing with both sets at an electronics store.
  5. Michael Gretton
    Jun 10, 2002
    27
    I can tell you that I own the HS500 and it is a wonderful set. DVDs are awesome and Xbox is breathtaking.
