Scott-C
- Jul 23, 2001
Happy New Year HTF! In the spirit on "new beginnings" I'm going to try to articulate a problem with my HT that's bothered me all year. I know with your help, I can start 2002 with this problem resolved. Bear with me as I explain...
The Equipment
Yamaha DSP-A3090 integrated amp
Monster Cable M351 subwoofer cable
DefTech PF15TL+ subwoofer
Avia Guide to Home Theater DVD
The Connection
I've connected one end of the sub cable to the line-level output on the back of the 3090 labeled "MONO SUBWOOFER". The other end is connected to the sub's "LFE In" input.
The Problem
The Yamaha 3090 has a feature/setting called "LFE Level" that is used to adjust the output level at the LFE channel. I have been assuming this is the setting I should access to calibrate my sub using Avia. The feature allows for a 20 Db adjustment range (-20 DB to 0 Db). While playing subwoofer test tones in Avia, I've tried to adjust this setting to match my sub to the rest of my speakers, but no matter what setting I choose, there is no difference. I can choose -20 Db, -10 Db, 0 Db, or anything in between, and the sub's level does not change one bit. In order to change the sub level, I have to go to the powered sub's volume control on the back of the sub and change it there. As a result of this problem, I have resigned myself to leaving the "LFE Level" at 0 Db, and adjusting the LFE level using the sub's amp level control. I'd much prefer, of course, to calibrate using the 3090's sub level control if possible.
The Question
How do I go about adjusting subwoofer level on the 3090? Do I have everything connected correctly? I have no idea why this won't work for me. I don't know if it's the connection, if this setting on my 3090 is defective, etc. I know of no other setting on the 3090 that allows the user to adjust the subwoofer level. Help! And, thanks in advance for reading this and for assisting.
The Equipment
The Connection
The Problem
The Question
