Tony Bee
- Jan 9, 2005
Hello all,
I have recently started putting together my first home theatre setup. This setup is actually inside my bedroom, but will be moved into a living room in the future. After listening to speakers, reading reviews, and looking for deals, I have purchased the following:
Pioneer VSX-D814
Athena AS-FS1 floorstanding front's
Athena AS-C1 center
Athena AS-P400 subwoofer
Good quality wires and cables
I am enjoying the sound of the system thusfar, but still need to purchase some rear speakers. Unfortunately, the listening/viewing position is from a bed against the wall, so I believe this will prohibit me from going 6.1. If I am wrong, please correct me. So I believe I am looking for 2 more speakers to add to my system. The obvious choice is to go with the Athena AS-B1 speakers. If I purchased these, they would have to be placed directly next to the bed on both sides, either on stands or wallmounted. Most likely they would not be able to sit behind the listening position. If I was able to use smaller satellite speakers, I would be able to mount them to the back wall at each corner, which would put them father from the listening position, and a little bit behind (or not, that would be my choice). The speakers in this case would have to be small, no more wide than 5", as the right rear speaker would be sitting in the area the door opens.
Would I be better off with matching Athena speakers very close to the listening position (much closer than the distance from the fronts), or with smaller satellite speakers at a better distance, but of a different brand? Also, am I right in believing 6.1/7.1 would not be possible with the listening position against the wall? There is no chance I can pull away from the wall. I've seen a pair of Infinity TSS-SAT750's which would be perfect size for about $200/pair. They do seem a bit expensive as the Athena bookshelf speakers are $50 less a pair, and much larger.
Any insight on my situation would be greatly appreciated.
Tony
Pioneer VSX-D814
Athena AS-C1 center
Tony
