Bobby C
- Dec 23, 2003
Hi All,
I am in the middle of a basement teardown & build up for a HT. When I tore down the old ceiling (basement), I decided while I'm at it why don't I cable for voice/data & TV for the upstairs as well. While I currently don't have cable, I currently have a couple of drops for cable. Another piece of info is I have a Leviton distribution box - where my voice & data can be routed, as well as a single in for CATV & multiple outs.
While I haven't decided on what service to use (Dish vs. DirecTV), I will install some sort of satellite service in the next couple of months. This is a small house, I don't see having more than 2 locations for the satellite, one in the HT (using a FP) and another in a study (although I wouldn't mind wiring for other rooms where I could move a receiver if I want the 2nd TV in a different room). So here's some questions:
1. As I understand it, a satellite run for each receiver goes back to the dish, right? In other words, I can't run one COAX in & split it.
2. If I ever want a Tivo (or similar), do I need to cable differently? With satellite, must a Tivo be a single location device or can a Tivo located in 1 room be routed to another for playback? This isn't a big deal, but I'm interested.
3. In my HT, I will be getting a HD receiver. From what I understand, most satellite doesn't offer much in local HD. If I have an exterior antenea to pick up OTA HD, can that integrate with a receiver? Or would I need a separate tuner for that? So if I that works (a receiver can take not only the satellite signal, but an OTA one as well) I'll probably need a cable drop to that location, right?
Any other cabling issues I should be aware of?
Thanks!
Bob
Thanks!
Bob
