Question re: Receiver runs hot!
Discussion in 'AV Receivers' started by Pamela, Aug 14, 2004.
  1. Pamela
    Pamela Supporting Actor
    Mar 14, 2001
    779
    I have an Onkyo 898, which I use as a pre/pro. My separate amp (Parasound Halo A52) runs hot, which I expect. However, I noticed that the receiver also gets very hot. I assumed that when I switched to a separate amp, the receiver wouldn't produce as much heat. Is this normal?
  2. Laurence_C
    Laurence_C Stunt Coordinator
    Sep 30, 2001
    174
    110
    North Florida Panhandle
    Laurence
    You don't give any specifics on how you have these set-up. Is one sitting on top of the other? Are they in a rack/cabinet? Is the rack/cabinet enclosed? Do they have ventilation? If so how much space on the top/sides?
  3. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    My rule of thumb is: if you can comfortably touch it, then it's definitely not too hot. Most electronics can stand temperatures we consider painfully hot. It's still possible to overheat an amplifier if you push it hard and the space is not ventilated. The receiver's amps are probably still working (though not in use) and produce as much heat as usual.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Yes, Pamela, how well is the equipment ventilated?
    I remember you once telling me that your kitties have sat on your computer monitor, clogging up the ventilation slats, with the obvious ruinous results.
    Prevent that fate from happening to your Onkyo.
  5. Pamela
    Mar 14, 2001
    779
    Interesting. I just assumed that because the receiver's amps were being bypassed, they wouldn't be on.
  6. Robert Cowan
    Robert Cowan Supporting Actor
    Nov 10, 2003
    504
    electronics can handle a LOT more heat than you think. most transistors are designed for 200F or higher.
    if you can touch it, you are fine.
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    They might be in some 'idle' mode. You could always ask for clarification from the manufacturer and if the heat is an issue you want to address, you could probably rig up a couple of compter fans to draw additonal air through the system.
