Question: POA-8200 w/ Denon 3801 Much Help?
Discussion in 'Archived Threads 2001-2004' started by James Elvick, Aug 11, 2001.
  1. James Elvick
    James Elvick Supporting Actor
    Jan 12, 1999
    690
    Hello,
    I have the opportunity to add a Denon POA8200 2 channel amp to my 3801 for Stereo listening. Do you think the additional amp will make much of a difference? The POA-8200 is rated at 120watts into 8 ohms and is THX certified.
    James
  2. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    James,
    I've never heard either the amp or the 3801 but I think you will find that it will help when you drive all 7 speakers at the same time.
    In essence you'll only be driving 5 channels with the 3801 and this will probably increasing the amount of power you get from those 5 channels.
    I've been thinking about doing the same for my 5800 by getting mono-blocks to drive the L, R and C.
    Patrick
    My DVD Collection
  3. James Elvick
    Jan 12, 1999
    690
    I think that the speakers I'm using could be a factor too! [​IMG] I have a Paradigm Studio setup w/ 40's/CC/20's. The Paradigm don't seem that hard to drive but have also read that they really sing with better amplication. The question is how much of an upgrade the POA-8200 would be? Anyone hear this combo? Denon POA-8200 with Studio 40's?
    James
    [Edited last by James Elvick on August 11, 2001 at 08:01 PM]
  4. Ricky T
    Ricky T Supporting Actor
    Oct 28, 1999
    921
    James,
    No more Lexicon DC2 with HK signature 1.5/2.1 amps?
    I used to have two poa8200s. IMO, the 8200 is a worthwhile upgrade over the 3801....but not as good as the HK signature 1.5 200x2 amp you used to have...which J&R still sells for $499 NIB.
  5. James Elvick
    Jan 12, 1999
    690
    Hi Ricky,
    This is the bedroom system! The Lex, HK, NHT setup remains! I want a little more juice mainly just for stereo and the price for the POA8200 is under $300. I'm hoping for a noticeable difference.
    James
