Question Pertaining to Grammar (adverb use)
Discussion in 'After Hours Lounge (Off Topic)' started by Chuck C, Oct 15, 2004.
  1. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    Which sentence sounds best:
    The climate of the contemporary workplace is changing dramatically.
    The climate of the contemporary workplace is dramatically changing.
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,839
    537
    9,110
    I like the first one. Neither is wrong, though.
  3. Jon_Gregory
    Jon_Gregory Stunt Coordinator
    Jan 10, 2004
    225
    The difference between the two is whether you want to put more emphasis on the word changing or dramatically. With the first one, it makes the word changing stand out more. In the second, the word dramatically stands out more.
  4. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    The first one. I don't know what is what in grammar, but it is the workplace that is changing. The extras should follow.
    Glenn
  5. nolesrule
    nolesrule Producer
    Aug 6, 2001
    3,084
    110
    Clearwater, FL
    Joe Kauffman
    Dammit, I can't find my grammar police manual, but I don't think you can separate "is changing".
  6. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,883
    752
    9,110
    Since 2006
    Cameron Yee
    Separating them is fine as far as I know. You may be thinking of splitting infinitives. For example, if it were "to change" some think it would be wrong to place the adverb before the verb.
    More info: http://www.bartleby.com/68/76/5676.html
  7. Chuck C
    Jan 6, 2001
    2,224
    thanks for the replies...
    jon.. your reply def. clarifies the issue (i.e. where to put emphasis). I'm going w/ sentence #1
  8. Seth Paxton
    Seth Paxton Lead Actor
    Nov 5, 1998
    7,585
    To add on to the advice so far, I think the key here is understanding what your audience already knows. If your point is that the reader will be surprised to know that things are changing then it comes first for the emphasis.
    However, if it is a case where you think the reader already somewhat understands that change is taking place, then putting dramatically first is probably better because your point to them isn't that there is change but that there is dramatic change.
  9. Nathan Eddy
    Nathan Eddy Second Unit
    Jan 22, 2004
    262
    I don't think it's a matter of emphasis as much as it is style. The last word in the sentence should be powerful and vivid. You don't want to end on a weak note. Sentences, paragraphs, and stories should all build to the climax. "Changing" is not nearly as exciting as "dramatically."
  10. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,395
    34
    1,610
    "on a little street in Singapore"
    Yee Ming Lim
    To me, I'd say the first version, but what do I know?
    Where's Rex Bachman, the grammar expert of HTF?
  11. Stacey
    Stacey Stunt Coordinator
    Feb 10, 2002
    174
    I like the first line also. I always find that given two words, people almost always put the word with fewer sylibals first followed by the longer sylibal words.
    Take for example, two names like Veronica and Betty...people always seem to put Betty first then Veronica because of the ammount of sylibals.
    [​IMG]
  12. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    I don't see anything wrong with either one.
    Seems like a matter of style, and where you want the emphasis.
