Question on the Pioneer DVR-A05
Discussion in 'Archived Threads 2001-2004' started by Kevyn, Feb 23, 2003.
  1. Kevyn
    Kevyn Auditioning
    Feb 23, 2003
    4
    While installing my A05, I noticed that there was this odd white connector on the far left side (if you're facing the back of the dvd-rw drive). I was unable to find any mention in the manual, or on pioneer's site about this connection. Does anyone have any insight on it? I'm sorry if this is in the wrong forum, but the description seemed to fit my question. Thanks for looking.
    [​IMG]
    Noticed this on pioneer's part's site, perhaps it's related?
  2. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
    I've got the A105, the OEM version of this drive. Just looked and it's not mentioned in the documentation for that drive either. I can tell you that I have nothing connected to it and my drive works fine. Perhaps it's something for the manufacturers use?
  3. David Norman
    David Norman Producer
    Oct 12, 2001
    3,780
    758
    4,110
    Had to say for sure, but I think it's a digital audio output. I have a Pioneer DVD 106 (non burner) and that's what that spot is listed as -- should be able to use a SPDIF cable to connect to a digital input.
  4. Kevyn
    Kevyn Auditioning
    Feb 23, 2003
    4
    Must be a weird spdif cable, as it's about half the size or less of the Analog connector. On all my other hardware, the spdif port is the same height as the analog connector, just 2 pins instead of 4
  5. Brian E
    Aug 12, 2000
    1,636
    If that's a spdif connector it's the strangest one I've ever seen.
  6. David Norman
    Oct 12, 2001
    3,780
    758
    4,110
    You may be right, I can't see the picture very well in the message, I was just going by the location in respect to the analog out comparing to the other Pioneer DVD.
