Tom Veillette
Grip
- Oct 8, 2004
Hey guys.
I have a Zenith HD CRT. I have been learning as much as I can about the set.
While looking through the service manual for a setting to enable/disable SVM, I learned that the SVM is on a separate plug-in board.
Anything wrong with just disconnecting the module?
Seems a bit too easy.
Unfortunately, it doesn't look like there's a setting to disable via software, so the hardware route may be the only way.
Anyone see anything wrong with this?
