Question on sony digital camcorders
Discussion in 'Playback Devices' started by Mark Giles, Jul 22, 2004.
  1. Mark Giles
    Mark Giles Second Unit
    Aug 30, 2002
    272
    Is there a way to disable the auto shut off feature when I'm not recording. For instance, when I'm using a tv to display realtime video from the camcorder (when I'm not recording or playing back recordered video) it will shut off after a minute or so. I would just like the camcorder to stay on until I turn it off. Is there a setting that will allow this?
  2. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    I think there is a setting for this. Check the manual. Mine does the same thing. A power saving feature that I believe can be disabled in the menu.
  3. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    972
    3
    Usually all you have to do is take the tape out and close the mechanism or door. It shuts off to keep from burning the heads against the tape.
