Newegg.com sells OEM DVD burners, so my question is do OEM devices come with at least the drivers ?
Feb 25, 2004 #1 of 7 anthony_b Screenwriter Joined Aug 18, 2000 Messages 1,077 Newegg.com sells OEM DVD burners, so my question is do OEM devices come with at least the drivers ?
Feb 25, 2004 #2 of 7 James T Screenwriter Joined Aug 8, 1999 Messages 1,643 Most of the time they do. Even if it doesn't, you can probably find it on the internet somewhere.
Feb 25, 2004 #3 of 7 WayneO Supporting Actor Joined Nov 10, 2003 Messages 625 Not necessarily drivers per se, but usually a DVD burning software program. Drivers aren't needed for windows to actually recongnize the drive in most cases.
Feb 25, 2004 #4 of 7 anthony_b Screenwriter Joined Aug 18, 2000 Messages 1,077 So am I safe to buy an OEM dvd burner with no drivers running XP home edition ?
Feb 25, 2004 #5 of 7 James T Screenwriter Joined Aug 8, 1999 Messages 1,643 You can always check MS Hardware Compatibility list. Here's the online verion http://www.microsoft.com/windows/cat...title=hardware
Feb 25, 2004 #6 of 7 T Travis Olson Supporting Actor Joined Oct 7, 2001 Messages 941 Real Name Travis Olson I bought an OEM CD burner from Newegg and it came with Nero and an IDE cable. You shouldn't need to install any drivers manually.
Feb 25, 2004 #7 of 7 Mike Fassler Supporting Actor Joined Jan 17, 2004 Messages 523 the burner wont require any drivers, only software you want to use to burn with, and you can pretty much use anything you want.
