Raphael O
- Jan 1, 2003
i want to build a flexi rack for my 32 inch toshiba TV and this thing weigh a ton (approx more than a hundred lbs ,maybe around 130).
i want to know if these supplies will work to hold it .
the rack will be around 40 inch wide ,20 inch deep and 24 inches high .
i will use 3/4 threaded rods - six of them for support - two on each side and two in the middle.
there will be 3 shelves - the lower would be around 12 inches and the upper will be whet is left over .
i want more room at the lower for the avr 8000.
what thickness mdf do u guys think i should go for?
would this design be able to support the tv ok?
need your input guys ok
