Jeff Pounds
- Jun 6, 2000
I recently purchased a new DVD player... Mits DD-8040.
It has a number of controls that my previous DVD player didn't have... noise reduction controls, black level controls, color and tint, gamma correction, etc.
I have a two-part question:
1. Should I be using the noise reduction controls? I do notice some block and mosquito noise in dark scenes on some DVDs, but are these noise reduction controls going to give me any undersirable effects, the way that VM on RPTVs gives you unwanted edge enahncment? The player has 3 different NR controls, if I remember correctly: mosquito-noise reduction, block-noise reduction and some other one that has something to do with color (can't remember exactly...)
2. How should I "weight" the DVD player picture controls (black level, white level, picture, tint) versus the TV's controls for the same options? Obviously, I could get in and calibrate with either... my gut instinct is just to keep my DVD player's levels at "zero" and adjust the TV's settings for the proper calibration. Of course, I will utilize the DVD player's gamma correction if needed.
Any help would be greatly appreciated!
Note to admins: I wasn't sure if this would go in this section or "Displays"... so please move if needed.
Thanks!
Thanks!
