Question on Denon 3802 dd dropouts
Discussion in 'Archived Threads 2001-2004' started by DonT, Nov 13, 2002.
  1. DonT
    DonT Stunt Coordinator
    Oct 4, 2002
    52
    I have noticed the Dolby Digital droput problem on a few DVDs Ive watched (on a very few) and usually it only happens once or twice during a viewing. However the last movie I watched, Mr. Deeds, had several dropouts. According to the Dolby Digital web site, they know the problems with the various flags in the bit stream and they encouraged DVD shops to stop using the format in question. They said, supposedly, that they were working on a fix for this in their encoding so that it wouldnt happen on the older receivers. My questions are, does anyone else have this problem with the 3802, does Denon have a fix for this, is it really necessary to get the fix if it only happens on a few DVDs and Dolby is supposedly working on the problem? Any guidance on tis issue would be helpful. Thanks. To see Dolby's response, go to
    http://dolby.custhelp.com/cgi-bin/do...cGFnZT0x&p_li=
    It just seems to me that if they were REALLY doing anything about this, that Mr. Deeds is such a new release, that any fix they would be implementing would have been done by then. This is just one more reason why I ALWAYS use DTS tracks when they are available.
  2. Duane_T
    Duane_T Stunt Coordinator
    Jul 30, 2001
    185
    Don, I watched Mr. Deeds a while ago - never experienced any dropouts - don't recall any other movies with dropouts either - this is on the 3802 as well.
  3. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
    Don, I have a 2802 and no dropouts with Mr.Deeds as well.
  4. DonT
    Oct 4, 2002
    52
    hmm, thats weird. i watched star wars II on it and that was a 2.5 hour movie in dd ex and it didnt drop out one time. i think the dropout problem may be an intermittent thing, and sometimes the flags affect the decoding and sometimes they dont. anyone have any ideas on this flag problem?
  5. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    I have the Denon 3801 and never have experienced a dropout on DVD. I have though on Satellite, but it was the broadcast....
  6. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    I too have a 3802 and have NEVER had any dropouts on any discs that were the fault of the 3802 (I run mine as 5.1.) However, I did have to replace my early generation DVD player because it started having trouble with some discs...
  7. DonT
    Oct 4, 2002
    52
    well like i said chuck, its only happened on a couple of the discs that ive watched out of maybe 200, so its highly possible that you just havent watched one that would cause it to do that. i started the thread due to dolby's faq on their site where they talk about the dropouts being their problem.
  8. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Don: In 3 cases, people were having drop-outs every few minutes and the problem was solved by changing their coaxial-digital cable. They were using audio cables by mistake, or a poorly-made cable.
    Even the correct cable, bent at a sharp 90 degrees can have it's impedence change. And over time, your cables sag and bend.
    So check your coaxial-digital cable. Make sure it comes out of your DVD player in a loose curve and goes into your receiver the same way. Then see if you still have drop-out problems.
  9. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    Never happened with my 3802 on any movies.
  10. TonyTone
    TonyTone Supporting Actor
    Jul 24, 2002
    728
  11. DonT
    Oct 4, 2002
    52
    i am using a toslink optical cable. could this have the same problem? also, like i said it only happens once in a while, not consistently. could it still be the cable?
  12. DonT
    Oct 4, 2002
    52
    well, ive replaced my cheaper cable with a 3 ft monster cable optical cable that i had on my better stereo system. does anyone think this will help, vs. the 6 ft recoton cable i was using?
  13. Bob McElfresh
    May 22, 1999
    5,182
  14. DonT
    Oct 4, 2002
    52
    well, i just watched insomnia and had at least 5 dropouts during the middle of the movie. im using the monster optical cable, so i dont think its the cable. im using a toshiba 4700 dvd player. noone else has had problems wiht the 3802 dropping out in DD mode, so i doubt its my decoder in my 3802. yet, it would seem that the dvd player just passes the digital signal, so how could it possibly be that? ive heard the dropouts the worst on two dvds i got from the library (one of which is insomnia). the dvds had a few marks on them but nothing that should make it bad, and there were no video problems. is it possible that my dvd player is causing the dropouts somehow?
  15. Robert_Z
    Robert_Z Screenwriter
    Jun 16, 2002
    1,017
    I am having DTS dropouts with my 3-month old 3802. But no DD dropouts.
  16. DonT
    Oct 4, 2002
    52
    robert, i only have a problem with ONE disk i own, thats a dokken music video dvd, and that doesnt always happen. all other dvds i have play fine. its only the library ones with small blemishes, but they dont look bad enough to cause a problem. i have had no problems at all with dts.
  17. Dan Kaps
    Dan Kaps Extra
    Mar 6, 2001
    16
    My 4700 also suffered DD dropouts (through both coaxial and optical) with my Outlaw 1050. I've since replaced it with a Panny RP82 and haven't had any dropouts since.
    (Also didn't have problems with an older Toshiba that the 4700 replaced)
    I would bet that it's your player. Do you/did you have any other player? PS2 or XBOX maybe that you could test with?
  18. DonT
    Oct 4, 2002
    52
    thanks dan. i will probably be replacing my unit soon with a sacd/dvd-audio player. im eyeing the pioneer elite one that is 400 or the onkyo that is 800. i really like the onkyo layout, especially the menu and control buttons on the front panel. i guess the genius engineers at pioneer think that people want to use the remote for everything. thats one thing i like about my 4700, is the menu and control buttons on the front panel.
